The On-Q/Legrand Shelf Mounting Bracket is the perfect solution for mounting plastic enclosures in your home or office. This sturdy bracket is designed to securely hold your enclosure in place, providing a stable and reliable mounting solution. It is compatible with a variety of plastic enclosures, making it a versatile choice for a range of applications. The bracket is easy to install and comes with all the necessary hardware, making it a hassle-free solution for your mounting needs. Whether you’re looking to mount a security system, entertainment center, or other device, the On-Q/Legrand Shelf Mounting Bracket is the ideal choice.
Manufacturer Part # | AC1060 |
UPC | 804428434627 |
Finish | Matte White |
Included | 2 Sets of Plunger/Grommets 2 Ft Hook and Loop Strap |
Type | Mounting Bracket |
Bracket | Plastic, vented, shelf mounting bracket for plastic structured wiring enclosure. |
Mounting | Inside Mount |
Compatibility | Legrand plastic structured wiring enclosure |
Capacity | 10lbs |
Certifications | RoHS This product meets the material restrictions of Article 4 of the RoHS Directive (2011/65/EU), including Commission Delegated Directive 2015/863. |
Environmental Conditions | 10 to 90% |
Max (verified owner) –
The product is firmly packed.
Paul (verified owner) –
Zohar (verified owner) –
Very fast delivery.
Kevin (verified owner) –
Very well worth the money.
Michael (verified owner) –
