The On-Q/Legrand 48-Port Cat6 Rack-Mount Patch Panel is the perfect solution for managing your network connections. This panel allows you to easily connect up to 48 Cat6 cables in a neat and organized manner. The panel is designed to be mounted in a standard 19-inch rack, making it easy to integrate into your existing network infrastructure. The high-quality construction of the panel ensures that it will stand up to the rigors of daily use, while the numbered ports make it simple to keep track of your connections. The On-Q/Legrand 48-Port Cat6 Rack-Mount Patch Panel is the ideal choice for anyone looking for a reliable, easy-to-use solution for managing their network connections.
Product Specs:
Cable Type | Cat6 |
Color | Black |
Mod Jack Wiring | T568A/B Universal |
Wiring Type | Rackmount Patch Panel |
Input Plug Type | RJ45 Male |
Material | Plastic and Steel |
Mounting | Rack |
Performance Rating | High-performance panel |
Product Fits Into | 19-inch rack |
Receptacle Type | RJ45 Female, 8P8C |
Number Of Receptacles | 48 |
Dimensions | 3.5(H) x 19(W) x 3(D) inches (8.89 x 48 x 8 cm) |
cU Lus | Yes |
FCC Standard | Yes |
Fed Spec Number | FCC Part 68 |
Henry (verified owner) –
Very fast delivery.
Edward (verified owner) –
Good quality.
Ryker (verified owner) –
Good quality.
Mateo (verified owner) –
The product is firmly packed.
Angel (verified owner) –
Very fast delivery.
