On-Q/Legrand 4-Way Digital Cable Splitter with Coax Network Support
(5.00)5 Reviews
Out of Stock
$12.08
SKU: OQVM2204V1
Brands:
The On-Q/Legrand 4-Way Digital Cable Splitter with Coax Network Support is the perfect solution for distributing high-quality digital cable signals to multiple devices in your home or office. With four output ports, you can connect up to four TVs, cable modems, or other devices to a single input source. This splitter is designed to maintain the integrity of your digital signal, ensuring that all of your devices receive the same high-quality picture and sound. Additionally, the coax network support allows you to easily connect your cable modem to your home network, providing a reliable and high-speed internet connection throughout your home. The compact and durable design of this splitter makes it easy to install and use, while the gold-plated connectors ensure a stable and corrosion-free connection. Whether you’re a home user or a professional installer, the On-Q/Legrand 4-Way Digital Cable Splitter with Coax Network Support is the perfect choice for distributing digital cable signals to multiple devices.
Product Specs:
Cable Type Coaxial
Color Black
Connection Type ANSI/SCTE 01 Compliant ECT
F-port Type Signal Splitter
Housing Material Zinc Alloy diecast
Surge Protected 6 kV ring wave surges per IEEE specification C62.41 Category A3
Frequency 5 to 1525 MHz
Ohm Value 75 Ohm Nominal impedance
Operating Temperature -40 to 140 degrees F (-40 to 60 degrees C)
Supported Standards Exceeds ANSI/SCTE 143 specifications for corrosion, 1000 hours
Diameter 3.3(L) x 1.8(W) x 0.6(D) inches (84.9 x 45.1 x 15.3 mm)
Customers Reviews
(5)
  1. Max (verified owner)
    Good service.
    1 product
  2. Max (verified owner)
    Very fast delivery.
    1 product
  3. Samuel (verified owner)
    Good quality.
    1 product
  4. Edward (verified owner)
    Good quality.
    1 product
  5. Lucas (verified owner)
    Very fast delivery.
    1 product
Back to Top
chatsimple
