The On-Q/Legrand 36-Port Cat5e Wall Mount Patch Panel is a must-have for any networking setup. This high-quality patch panel allows for easy organization and management of your Cat5e cables, with 36 ports for connecting your devices. The wall mount design makes it easy to install and keeps your cables neatly tucked away. The panel is built to last, with a durable construction that can withstand heavy use. It also features color-coded wiring diagrams for easy installation and maintenance. Whether you’re setting up a small home network or a large business system, the On-Q/Legrand 36-Port Cat5e Wall Mount Patch Panel is the perfect solution.
Product Specs:
Cable Type | Cat5e |
Color | Black |
Mod Jack Wiring | T568A/Universal |
Wiring Type | Wall-Mount Jack Panel |
Input Plug Type | RJ45 Male |
Receptacle Type | RJ45 Female |
Number Of Receptacles | 36 |
Dimensions | 6.94(H) x 10.69(W) x 3.08(D) inches (17.6 x 27.2 x 7.8 cm) |
Bryan (verified owner) –
Very well worth the money.
Ryker (verified owner) –
The product is firmly packed.
Avery (verified owner) –
Hayden (verified owner) –
Good quality.
Kaden Arabic (verified owner) –
