On-Q/Legrand 3-Way Digital Cable Splitter with Coax Network Support
(5.00)5 Reviews
Out of Stock
$9.95
SKU: OQVM2203V1
Brands:
The On-Q/Legrand 3-Way Digital Cable Splitter with Coax Network Support is the perfect addition to your home entertainment setup. This high-quality splitter allows you to distribute digital cable signals to up to three different devices. With its advanced coax network support, you’ll experience crystal-clear picture and sound quality, no matter which device you’re using. The compact design makes it easy to install, and the durable construction ensures long-lasting performance. Whether you’re watching TV in the living room, bedroom, or basement, the On-Q/Legrand 3-Way Digital Cable Splitter with Coax Network Support ensures a seamless viewing experience every time.
Product Specs:
Cable Type Coaxial
Color Black
Connection Type ANSI/SCTE 01 Compliant ECT
F-port Type Signal Splitter
Housing Material Zinc Alloy diecast
Surge Protected 6 kV ring wave surges per IEEE specification C62.41 Category A3
Frequency 5 to 1525 MHz
Ohm Value 75 Ohm Nominal impedance
Operating Temperature -40 to 140 degrees F (-40 to 60 degrees C)
Supported Standards Exceeds ANSI/SCTE 143 specifications for corrosion, 1000 hours
Diameter 3.3(L) x 1.8(W) x 0.6(D) inches (84.9 x 45.1 x 15.3 mm)
Customers Reviews
(5)
  1. Henry (verified owner)
    The product is firmly packed.
    1 product
  2. Michael (verified owner)
    1 product
  3. Nolan (verified owner)
    Good service.
    1 product
  4. Henry (verified owner)
    Good service.
    1 product
  5. Mateo (verified owner)
    Very well worth the money.
    1 product
Back to Top
chatsimple
