The On-Q/Legrand 2-Way Digital Cable Splitter with Coax Network Support is a versatile and high-quality device that allows you to split your digital cable signal and distribute it to multiple devices. With support for coax network connections, this splitter is perfect for use in modern homes that require multiple connections for televisions, cable modems, and other digital devices. The splitter features a durable and compact design that allows for easy installation and integration into your existing system. Whether you’re looking to expand your home entertainment system or simply need to distribute your cable signal to multiple devices, the On-Q/Legrand 2-Way Digital Cable Splitter with Coax Network Support is the perfect solution.
Product Specs:
Cable Type | Coaxial |
Color | Black |
Connection Type | ANSI/SCTE 01 Compliant ECT |
F-port Type | Signal Splitter |
Housing Material | Zinc Alloy diecast |
Surge Protected | 6 kV ring wave surges per IEEE specification C62.41 Category A3 |
Frequency | 5 to 1525 MHz |
Ohm Value | 75 Ohm Nominal impedance |
Operating Temperature | -40 to 140 degrees F (-40 to 60 degrees C) |
Supported Standards | Exceeds ANSI/SCTE 143 specifications for corrosion, 1000 hours |
Diameter | 2.3(L) x 1.8(W) x 0.64(D) inches (59.6 x 45.1 x 16.3 mm) |
Zohar (verified owner) –
Good quality.
Ryker (verified owner) –
Very well worth the money.
Matthew (verified owner) –
Very fast delivery.
Tyler (verified owner) –
Very fast delivery.
The product is firmly packed.
