The On-Q/Legrand 12-Port Cat5e Wall-Mount Patch Panel with 89D Bracket is the perfect solution for organizing and managing your network connections. This high-quality patch panel is designed to provide reliable performance and easy installation in any residential or commercial setting. With 12 ports, it can accommodate multiple devices, including computers, printers, and IP phones, making it ideal for small to medium-sized networks. The included 89D bracket allows for easy installation on any wall, and the panel’s compact design ensures that it won’t take up too much space. Plus, the Cat5e rating ensures that your network will run at optimal speeds with minimal interference. Whether you’re upgrading your existing network or building a new one from scratch, this patch panel is the perfect choice for a professional, organized installation.
Manufacturer Part # | 12845C5E89 |
Cable Type | Cat5e |
Color | Black |
Mod Jack Wiring | T568A/Universal |
Wiring Type | Wall-Mount Patch Panel |
Input Plug Type | RJ45 Male |
Receptacle Type | RJ45 Female Jack |
Number of Receptacles | 12 |
Dimensions | 10(H) x 2.25(W) x 1.625(D) inches (25.4 x 5.7 x 4.13 cm) |
Ryan (verified owner) –
Good service.
Liam (verified owner) –
Good service.
Isaac (verified owner) –
Very fast delivery.
Julian (verified owner) –
Good quality.
The product is firmly packed.
