The On-Q/Legrand 10×8 Combo Module RJ45 with RJ31X is the perfect solution for your networking needs. With 10 RJ45 ports and 8 RJ31X ports, this module lets you connect multiple devices to your network, including computers, printers, and other peripherals. The RJ31X port also allows you to connect your security system to your network, providing you with an added layer of protection. This module is easy to install and comes with all the necessary hardware. It is designed to fit into a standard On-Q/Legrand enclosure, making it a convenient addition to your home or office network. With its reliable performance and versatility, the On-Q/Legrand 10×8 Combo Module RJ45 with RJ31X is the ideal choice for your networking needs.
Product Specs:
Cable Type | Cat 5, Cat5e, Cat 6, Coaxial |
Color | Black |
Connection Type | RJ45, F Connector, RJ31X |
Type | Telecom/Video Module |
Surge Protected | Splitter: Surge Withstand 6 kV Ring Wave Surge per IEEE C62.41 Category A3 |
Frequency | 5 MHz-1002 MHz |
Material | 18 Gauge Cold Rolled Steel |
Mounting | Enclosure |
Ohm Value | Splitter: Nominal impedance 75 Ohms |
Operating Temperature | 40 to 140 degrees F (-40 to 60 degrees C) |
Receptacle Type | RJ45(10), F Connector(8), RJ31X(1) |
Number of Receptacles | 19 |
Dimensions | 6(W) x 5(H) x 3.1(L) inches (15.2 x 12.7 x 7.9 cm) |
Weight | 1.485 pounds |
UL Standard | Yes |
UN SPS C | 43222819 |
Edward (verified owner) –
Very well worth the money.
Camden (verified owner) –
Patrick (verified owner) –
Michael (verified owner) –
Julian (verified owner) –
The product is firmly packed.
