NuTone Central Vacuum Supervalves Electrified Inlet
(5.00)5 Reviews
Out of Stock
$16.95
SKU: NUCI358W
Brands:
The NuTone Central Vacuum Supervalves Electrified Inlet is the ultimate solution for all your cleaning needs. Designed with cutting-edge technology, this electrified inlet is compatible with all NuTone central vacuum systems, providing an unmatched level of convenience and performance. With its sleek and modern design, the Supervalves Electrified Inlet blends seamlessly into any home decor and offers an easy-to-use interface for effortless cleaning. The electrified inlet is equipped with a powerful motor, which provides superior suction power to remove even the toughest dirt and debris from your floors and carpets. The inlet features a retractable hose that can be easily extended to reach every corner of your home, making cleaning a breeze. The inlet also features a convenient on/off switch, allowing you to control the power of your central vacuum system with ease. The Supervalves Electrified Inlet is built to last, with a durable construction that can withstand years of heavy use. The inlet is also easy to install, with a simple and straightforward installation process that can be completed in just a few minutes. With its exceptional performance and ease of use, the NuTone Central Vacuum Supervalves Electrified Inlet is the perfect addition to any home cleaning system.
Manufacturer Part #: CI358W
Material: Molded using rigid PVC
UL Listing: UL listed
CSA Approval: CSA approved
Customers Reviews
(5)
  1. Lucas (verified owner)
    Very fast delivery.
    1 product
  2. Aiden (verified owner)
    The product is firmly packed.
    1 product
  3. Robert (verified owner)
    Good service.
    1 product
  4. Camden (verified owner)
    Good quality.
    1 product
  5. Richard (verified owner)
    Very fast delivery.
    1 product
Back to Top
chatsimple
