Leviton Decora Smart Z-Wave Plus v2 Fan Speed Controller, Gen7
Regular price $92.58
Regular price $92.58 Sale price
Introducing the Leviton Decora Smart Z-Wave Plus v2 Fan Speed Controller, Gen7 - the ultimate solution for controlling your home's ceiling fans with ease and convenience. This cutting-edge device is designed to work seamlessly with your Z-Wave enabled smart home system, allowing you to control your fan speed and turn your fan on or off from anywhere using your smartphone or voice assistant.
The Leviton Decora Smart Z-Wave Plus v2 Fan Speed Controller, Gen7 is built with the latest Z-Wave Plus technology, ensuring a reliable and secure connection to your smart home system. It also features a sleek and modern design that seamlessly integrates with your home's decor.
With its advanced features and intuitive controls, this fan speed controller is the perfect addition to any smart home. It allows you to set schedules, create scenes, and customize your fan speed to your liking. Plus, it's easy to install and works with most ceiling fans, making it a versatile and convenient solution for any home.
Upgrade your home's ceiling fan with the Leviton Decora Smart Z-Wave Plus v2 Fan Speed Controller, Gen7 and enjoy the ultimate convenience of smart home automation.
Manufacturer Part #: ZW4SF-1BW
UPC: 078477588543
Brand: Decora Smart Z-Wave
Device Type: In-Wall Smart Fan Speed Controller
Grade: Residential
Hub Required: Yes
Ratings: 1.5A – 120VAC, 50/60Hz
Neutral Required: Yes
Termination: Wire Leads
Voltage: 120VAC, 50/60Hz
Network: Wi-Fi: 802.11 a/b/g/n @ 2.4GHz
Security: wpa or wpa2
Strap Material: Metal
Operating Temperature: 32°F to 104°F (0°C to 40°C)
Operating Humidity: 0-90% non-condensing
Agency Standards and Compliance: UL, FCC, CSA, NOM, Z-Wave
Warranty: 2-Year Limited
