Aeotec Z-Wave Plus v2 illumino Dimmer Wall Switch, Gen7
Regular price $47.99
Regular price $47.99 Sale price
Shop Aeotec Illumino Dimmer Switch With Smart, Sleek, and Efficient
The Aeotec Dimmer Switch is a smart lighting solution that transforms your traditional light switch into an intelligent control hub. By integrating seamlessly with Z-Wave technology, it offers enhanced control over your lighting system, allowing for dimming, scheduling, and automation.
  • Dimming Control: Adjust the brightness of your lights to create the perfect ambiance.
  • On/Off Control: Easily turn your lights on or off remotely.
  • Scheduling: Set timers to automate your lighting based on your daily routines.
  • Automation: Integrate with other smart home devices for responsive lighting scenarios.
Compatibility
The Z-Wave Smart Dimmer Switch is compatible with a wide range of bulbs, including:
  • LED Bulbs: Supports up to 150W.
  • Incandescent and Halogen Bulbs: Supports up to 500W.
  • CFLs: Supports up to 150W.
Installation
Designed for easy installation, the Aeotec Illumino Dimmer features clearly marked wiring terminals and is compatible with standard single and multi-gang backing boxes. Its compact design ensures a perfect fit without compromising safety.
  • Enhanced Control: Gain precise control over your lighting, enhancing comfort and convenience.
  • Energy Efficiency: Optimize energy consumption by adjusting light levels and scheduling.
  • Smart Integration: Easily integrates with other smart home devices for a cohesive automation experience.
Elevate your home lighting experience with the Aeotec Dimmer Switch, a reliable and efficient solution for modern living.
Manufacturer Part #: ZWA037-A
Wireless Technology: Z-Wave
Z-Wave Plus: Yes
Series 700: Yes
Repeater: Yes
Beaming: Yes
Security Class: S2 auth, S2 unauth, Non-Secure
SmartStart: Yes
Input Voltage: 110/120 VAC 50/60Hz
Max Standby Power: 0.6W
Minimum Load: 5W with LED bulbs
Neutral Required: Yes
Continuous Maximum Load: 500W using incandescent/halogen
150W using LED bulbs (Trailing Edge)/dimmable CFL
Power Type: Wired
Operating Temperature: 32°F to 122°F (0°C to 50°C)
Operating Humidity: 8% to 80%
Operating Distance: 114 ft (35m) Indoor, 492 ft (150m) Outdoor
Product Dimensions: 4.13 x 1.8 x 1.57 inches (105 x 46 x 40 mm)
Product Weight: 0.33 lbs (150g)
Aeotec Z-Wave illumino Dimmer Switch
