Leviton Decora Smart Z-Wave Plus Dimmer Wall Switch, 600W
0 Reviews
In Stock
$65.95
SKU: LVDZ6HD1BZ
Brands:
Ezlo: Shop Leviton Decora Smart Z-Wave Plus Dimmer Wall Switch
Transform any room into a smart space with the Leviton Decora Smart Z-Wave Plus Dimmer Wall Switch. This innovative wall dimmer switch seamlessly integrates into your existing wiring, transforming any room with the magic of smart lighting control. The switch is designed to work with incandescent, LED, and CFL bulbs, making it a versatile addition to any home. With a maximum load capacity of 600W, it’s ideal for use in larger rooms or areas where additional lighting is needed. Integrate the dimmer wall switch with your compatible smart home hub (not included) and unlock a world of possibilities.
The Leviton Decora Dimmer boasts superior versatility, working flawlessly with a variety of bulb types. Plus, the sleek, modern design blends seamlessly with any decor and the user-friendly interface makes it easy to set up and control. Whether you’re looking to save energy, enhance your home security, or simply improve your living space, the Leviton Decora Smart Z-Wave Plus Dimmer Wall Switch is the perfect solution.
But functionality isn’t all this smart dimmable light switch offers. The sleek Decora design complements any décor style, adding a touch of modern elegance to your walls.
Package Includes: Device, Color Change Kits
Embrace the Advantages of Smart Dimming with Ezlo:
  • Effortless Control
  • Enhanced Convenience
  • Seamless Integration
  • Energy Efficiency
  • Unparalleled Versatility
  • Modern Design
Invest in the future of home lighting with the Leviton Decora Z-Wave Plus Dimmer Wall Switch from Ezlo. Experience the ease of smart control, create the perfect ambiance, and elevate your living space to a whole new level.
Manufacturer Part #: DZ6HD-1BZ
Load Rating:
  • Incandescent: 600W – 120VAC, 60Hz
  • LED/CFL: 300W – 120VAC, 60Hz
Approvals: Complies with UL 1472
FCC Listing Part 15 and Part 18
Z-Wave Plus Certified
UL required air gap switch disconnects power from load locally. It is concealed during normal operation and is accessible without moving the wallplate.
Warranty: 5 Year Limited
Customers Reviews
There are no reviews yet.
• Datasheet Pdf
Back to Top
chatsimple
