Leviton Basic Home Networking Plus Panel
(5.00)5 Reviews
Out of Stock
$115.88
SKU: LV47606BNP
Brands:
The Leviton Basic Home Networking Plus Panel is the perfect solution for all your home networking needs. This panel is designed to simplify your home network while providing you with reliable and fast internet access. With its easy-to-use interface, you can easily manage and control your network from anywhere in your home. The panel features a 1 GHz high-speed splitter and a 10/100 Mbps Ethernet switch, which allows you to connect all your devices to the internet with ease. You can also easily expand your network by adding additional modules to the panel. The Leviton Basic Home Networking Plus Panel is compact and easy to install, making it the perfect solution for any home. Get connected and stay connected with the Leviton Basic Home Networking Plus Panel.
Product Specs:
Cat5e Voice Data Module 1
Telephone Patching Expansion Board 1
6-Way 2 GHz Video Splitter 1
Standards and Certifications CULUS/FCC/TIA/EIA
Warranty 2 Year Limited
Design Considerations Determine outlet locations and carefully plan cable routing to ensure the selected unit satisfies requirements. Expansion boards available separately. Install 75 Ohm termination caps on unused outputs of 6-way 2 GHz Video Splitter to reduce signal distortion or ghosting. Use Video Amplifier (48210-VA) for increased signal strength. Mechanical
Customers Reviews
(5)
  1. Kayden (verified owner)
    Very fast delivery.
    1 product
  2. Paul (verified owner)
    Good quality.
    1 product
  3. Aiden (verified owner)
    Good quality.
    1 product
  4. Avery (verified owner)
    Very fast delivery.
    1 product
  5. Liam (verified owner)
    Very fast delivery.
    1 product
Back to Top
chatsimple
