The Greenfield Z-Wave Automatic Security Valve Kit is the perfect solution for protecting your home or business from water damage caused by leaks or burst pipes. This kit includes a high-quality 1.5-inch valve that can be easily installed on your water main, allowing you to remotely shut off your water supply at the first sign of trouble.
The Z-Wave technology allows you to control the valve from your smartphone or computer, giving you peace of mind and the ability to act quickly in the event of an emergency. The kit also includes a water sensor that can be placed in areas prone to leaks, such as under sinks or near appliances, which will automatically trigger the valve to shut off the water supply if water is detected.
With its durable construction and reliable performance, the Greenfield Z-Wave Automatic Security Valve Kit is an essential investment for any homeowner or business owner looking to protect their property from costly water damage.
There are no reviews yet.
