The Greenfield Z-Wave Automatic Security Valve Clamp-On Actuator is the perfect addition to your home security system. Designed to provide enhanced safety and protection, this actuator is built with advanced Z-Wave technology that allows you to remotely control your valve from your smart device. With this actuator, you can easily monitor and control your home’s water supply, gas flow, and oil supply, ensuring that everything runs smoothly and safely. The clamp-on design makes installation quick and easy, and the actuator is built to withstand even the toughest conditions. Whether you’re looking to safeguard your home against potential water leaks, gas leaks, or other hazards, the Greenfield Z-Wave Automatic Security Valve Clamp-On Actuator is the perfect solution. Order yours today and enjoy peace of mind knowing that your home is protected.
Manufacturer Part # | ASVCOA-Z |
Warranty | 1 Year |
Clamp-On Actuator (ASVCOA) | Power Source: 12/24 volt DC or 24 volt AC power supply (included) Input: 100-240V ~50/60Hz 1.0A MAX Output: 18V 2.22A Housing Ratings: NEMA 6P (waterproof); NEMA 7D (ignition proof) Approvals: UL listed |
FortrezZ MIMOlite (MIMOLITEUS) | Power: 9-16 VDC from a power supply at ~300mA capability (included) Frequency: 908.4MHz (U.S.) Z-Wave Wireless Range: Max 100 feet line of sight in unobstructed environment Input Signal 1 (SIG1): Digital or Analog Input 0 to 16VDC or 16 Hz Max for pulse counting (minimum 32 ms high or low time). The trigger levels and hysteresis can be set via the Configuration Command Class for the two endpoints. Input Signal Impedance: For SIG1: Z=66 ohms at 10KHz. This impedance is = 66 ohm = 34 ohm + j 540uH. Output Relay 1: DPDT, Max. Switching power of 120W; 10uA to 10A; High Dielectric strength coil-contacts: 1,000VAC. Open Contacts: 750VAC; Conforms to FCC Part 68 requirements; Ag + Au clad bifurcated contacts fully sealed. System Requirement: Any Z-Wave enabled network and controller Operating Temperature: 14° to 158°F (-10° to 70°C) Enclosure Size: 3-3/8(L) x 2-1/2(W) x 1-1/4(D) inches (85 x 64 x 30mm) Weight: 4 ounces (100 g) Approvals: FCC, IC |
Jackson (verified owner) –
Very fast delivery.
Good service.
Leo (verified owner) –
Very fast delivery.
Patrick (verified owner) –
Good service.
Isaac (verified owner) –
Very fast delivery.
