FIBARO Z-Wave Plus RGBW Controller 2
0 Reviews
In Stock
$55.95
Buy now
SKU: FBFGRGBWM442
Brands:
Shop Fibaro Z-Wave Plus RGBW Controller With Elevate Your Smart Home Experience
The Fibaro Z-Wave Plus RGBW Controller is a versatile device designed to enhance your home’s lighting experience. This universal controller allows you to manage various lighting sources, including RGB/RGBW LED strips, single-color LED strips, halogen lights, and other compatible resistive loads. By integrating this controller into your smart home system, you can create dynamic lighting scenes that adapt to your mood and activities.
  • Universal Compatibility: The FIBARO RGBW Controller is compatible with any certified Z-Wave or Z-Wave Plus controller, ensuring seamless integration into your existing smart home setup.
  • Diverse Lighting Control: Manage up to four lighting sources simultaneously, including RGB/RGBW LED strips, single-color LED strips, halogen lights, and other compliant resistive loads.
  • Advanced Inputs: Connect momentary or toggle switches and 0-10V analog sensors (such as temperature, humidity, or light sensors) to customize your lighting environment further.
  • Energy Monitoring: Monitor active power consumption and total energy usage, allowing you to optimize energy efficiency and reduce costs.
  • Enhanced Security: Supports Z-Wave network Security Modes, including S0 with AES-128 encryption and S2 Authenticated with PRNG-based encryption, ensuring secure communication within your smart home network.
  • Signal Repeater Functionality: Acts as a Z-Wave signal repeater, enhancing the reliability and range of your Z-Wave network by extending signal coverage.
  • Customizable Lighting Scenes: Create personalized lighting scenes that match your activities, whether a cozy ambiance for movie nights or bright illumination for reading.
  • Mood Enhancement: Adjust light colors and intensities to influence the atmosphere of your home, promoting relaxation, focus, or energy as needed.
  • Energy Efficiency: Utilize energy monitoring features to track and manage power consumption, potentially saving electricity bills.
  • Smart Home Integration: Integrate with other smart home devices and systems for a cohesive, automated living environment.
Specifications
  • Power Supply: 12/24V DC ±10%
  • Rated Load Current: 6A per channel; 12A total for all outputs
  • Power Output: 144W combined for 12V; 288W combined for 24V
  • Inputs: 4 inputs, 0-10V (configurable pull-up) or binary
  • Outputs: 4 outputs, PWM
  • Operating Temperature: 0–40°C (32–104°F)
  • Storage Temperature: -40–60°C (-40–140°F)
  • Radio Protocol: Z-Wave (500 series chip)
  • Radio Frequency: 908.4 / 916 MHz
  • Range: Up to 50m (164 ft) outdoors; up to 40m (131 ft) indoors (depending on terrain and building structure)
  • Dimensions: 42.35 x 36.90 x 17.5 mm (1.67” x 1.5” x 0.69”)Elevate your home’s lighting capabilities with the Fibaro Z-Wave Plus RGBW Controller, offering flexibility, control, and energy efficiency to suit your lifestyle.
  • Transmit Power: EIRP max. +2dBm
Customers Reviews
There are no reviews yet.
Back to Top
chatsimple
