Shop Fibaro Z-Wave Flood Sensor - 5th Generation
The Fibaro Z-Wave Flood Sensor, Gen5 is a state-of-the-art water detection device designed to safeguard your home or office from potential water damage. With its advanced Z-Wave flood sensor technology, this device detects even the smallest presence of water, instantly alerting you through your Z-Wave network to prevent costly damage. The sleek and compact design allows for easy installation in any location, whether it’s under sinks, near water heaters, or in basements.
The Fibaro flood sensor not only detects water but also monitors temperature, providing added protection against freezing pipes. The Gen5 version features enhanced accuracy and extended battery life, ensuring reliable and long-term performance. With its ability to integrate seamlessly into any smart home system, this Fibaro water sensor is a crucial addition to your home automation setup, offering peace of mind by proactively protecting your property from water-related disasters.
Usage:
Install the Fibaro Z-Wave Flood Sensor in areas prone to leaks or flooding, such as bathrooms, kitchens, basements, or utility rooms. The sensor will immediately notify you via your Z-Wave network if water is detected, allowing you to take swift action to prevent damage. Its temperature monitoring feature also alerts you to potential freezing conditions, helping to avoid burst pipes.
Benefits:
Early Detection: Instantly alerts you to the presence of water, allowing for prompt response.
Temperature Monitoring: Provides additional protection against frozen pipes.
Compact Design: Easily fits in tight spaces for discreet monitoring.
Enhanced Battery Life: Long-lasting performance ensures continuous protection.
Smart Home Integration: Seamlessly integrates with your existing Z-Wave system for comprehensive home automation.
Importance:
Water damage can lead to significant repair costs and inconvenience. The Fibaro Z-Wave Flood Sensor provides an essential layer of protection, ensuring that any potential water issues are detected early, preventing extensive damage. Its integration with Z-Wave technology enhances your overall home security system, making it a vital component in protecting your property.
Product Specs:
Manufacturer Part #: |
FGFS-101 ZW5 |
Power Supply: |
12-24 VDC |
Battery Type: |
1x CR123A (3.6V) battery (included) |
Power Consumption: |
0.4W at VDC operation |
Voltage at Output Terminals: |
40V (AC or DC): – EMC 2004/108/EC |
Radio Protocol: |
Z-Wave Plus |
Radio Frequency: |
908.4 MHz U.S. |
Wireless Range: |
up to 164 feet outdoors; up to 98 feet indoors (depending on terrain and building structure) |
Operational Temperature: |
50° to 104°F |
Temperature Measuring Accuracy: |
0.5° Fahrenheit (from 32° to 104°F) |
Dimensions: |
2.8(Dia) x 1.1(H) inches |
Certifications: |
Z-Wave Plus |
Warranty: |
12 months |
