Ezlo WiFi + Z-Wave Smart Water Shut-Off Built-in Smart Hub & Ball Valve Kit – 1″
(5.00)5 Reviews
In Stock
$299.95 $270
(-10%)
Ezlo Smart Water Shut-Off Valve With Built-In Smart Hub (Control Module Only)
In Stock
1’’ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
In Stock
In Stock
SKU: EZL-WV1BV100-US
Ezlo Smart Water Shut-Off with Built-in Smart Hub – Water damage is the leading cause of insurance claims and nearly 45% of the population has experienced water damage in their home or knows someone directly affected. With an average claim of over $11,000, it’s time to get smart about water and freezing damage. The Ezlo Smart water shut-off valve is the industry’s smartest water management solution, featuring a two-part design — ball valve and actuator — that distinguishes it from every other shut-off valve on the market. Unlike other automatic water shut-off valves that use the property’s original low-cost water shut-off valve, the Ezlo smart water shut-off valve actuator sits atop a custom, high-quality valve tested to withstand the test of time to control the flow of water.
This bundle comes with a 1″ Ball Valve. If your home has a different pipe size, please choose the correct valve size from this catalog.
Manufacturer Part #: ESWV1-US / EZLO-BV-1.00
UPC: 850010800141
Description: Gen II Automated Water Shut-off Valve – Z-Wave Hub
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 700 Series Chip
Networking: 802.11 g/n/ac Dual Band WiFi 2.4 & 5GHz
Approvals: FCC, IC
Additional information
Size:
Size:
Size:
Customers Reviews
(5)
  1. Anthony (verified owner)
    Good service.
    1 product
  2. Leo (verified owner)
    Good quality.
    1 product
  3. Leo (verified owner)
    The product is firmly packed.
    1 product
  4. Nicholas (verified owner)
    Good quality.
    1 product
  5. Kai (verified owner)
    1 product
Back to Top
chatsimple
