Ezlo WiFi + Z-Wave Smart Water Shut-Off Built-in Smart Hub & Ball Valve Kit – 3/4″
0 Reviews
In Stock
$364.90
Ezlo Smart Water Shut-Off Valve With Built-In Smart Hub (Control Module Only)
In Stock
3/4" Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
In Stock
In Stock
SKU: EZL-WV1BV075-US
Brands:
Shop Ezlo WIFI ZWaveSmart Water Shut-Off Valve Leak Detection Water
The Ezlo Smart Water Shut-Off Valve is an advanced solution designed to protect your home from water damage by automatically controlling your main water supply. Featuring a built-in Z-Wave Hub, this device not only manages water flow but also integrates seamlessly with your smart home system, allowing for centralized control and automation.
  • Automatic Leak Detection: When paired with compatible leak detection water sensors, the valve can automatically shut off the water supply upon detecting leaks, preventing potential damage.
  • High-Quality Construction: Equipped with a durable water ball valve, the system ensures reliable operation and longevity.
  • Smart Home Integration: The built-in Z-Wave Hub allows for easy integration with various smart home devices, enabling customized automation and remote control via the MiOS or Vera Mobile app.
Install the Ezlo Smart Water Shut-Off Valve on your home’s main water line. Once connected, pair it with leak detection water sensors to monitor for potential leaks. In the event of a detected leak, the system will automatically close the water ball valve, stopping the water flow to prevent damage. You can also control the valve remotely through the associated app, providing flexibility and peace of mind.
  • Prevent Water Damage: By automatically shutting off the water supply during leaks, it safeguards your property from costly repairs.
  • Enhanced Convenience: Remote control and automation capabilities allow for effortless management of your home’s water system.
  • Seamless Integration: The built-in Z-Wave Hub facilitates easy connection with other smart devices, creating a cohesive and efficient smart home ecosystem.
Incorporating the Ezlo Smart Water Shut-Off Valve into your home not only enhances safety by preventing water damage but also adds a layer of convenience through its smart features and integrations.
Manufacturer Part #: ESWV1-US / EZLO-BV-0.75
UPC: 850010800141
Description: Gen II Automated Water Shut-off Valve – Z-Wave Hub
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 700 Series Chip
Networking: 802.11 g/n/ac Dual Band WiFi 2.4 & 5GHz
Approvals: FCC, IC
Additional information
Size:
Size:
Size:
Customers Reviews
There are no reviews yet.
Back to Top
chatsimple
