Enbrighten Z-Wave Plus Split Duplex Wall Receptacle, Tamper-Resistant
(5.00)5 Reviews
Out of Stock
$57.95
SKU: JA55256
Brands:
The Enbrighten Z-Wave Plus Split Duplex Wall Receptacle, Tamper-Resistant is an innovative and efficient solution for your home automation needs. This tamper-resistant receptacle is designed to provide you with the highest level of convenience and safety in Ezlo.  Featuring the latest Z-Wave Plus technology, it allows you to remotely control and monitor your home appliances and devices from anywhere in the world using your smartphone or tablet.
This split duplex wall receptacle is perfect for homes with multiple devices that require power simultaneously. It comes with two standard receptacles that can be used independently or simultaneously to charge your phones, laptops, and other electronic devices. The tamper-resistant design provides added safety by preventing accidental contact with electrical components.
The Enbrighten Z-Wave Plus Split Duplex Wall Receptacle is easy to install and can fit into most standard wall boxes. Its sleek and modern design blends seamlessly with any home decor, making it a stylish and functional addition to your home. With its energy-efficient design and advanced features, this wall receptacle is the perfect choice for homeowners who want to improve their home automation capabilities.
Manufacturer Part #: 55256
UPC: 030878552561
Color: White
Power: 120 VAC, 60 Hz
Protocol: Z-Wave Plus
Frequency: 908.4/916 MHz
Total max load for both outlets: 1800W (15A), Resistive load
Max load for Z-Wave controlled outlet: 960W incandescent, 1/2 HP Motor, or 1800W (15A) Resistive
Wireless Range: Up to 150 feet line of sight between the Wireless Controller and the closest Z-Wave receiver module
Environmental Conditions: For indoor use only
Operating Temperature Range: 32° to 104°F (0° to 40°C)
Warranty: 2 Years
Customers Reviews
(5)
  1. Kaden Arabic (verified owner)
    The product is firmly packed.
    1 product
  2. Nathaniel (verified owner)
    1 product
  3. Zohar (verified owner)
    Good service.
    1 product
  4. Edward (verified owner)
    1 product
  5. Kevin (verified owner)
    Good quality.
    1 product
• Datasheet Pdf
Back to Top
chatsimple
