Communication Security Wire 22AWG 4C Shielded with Drain, Plenum Rated, 1,000 Ft.
Regular price $238.95
Regular price $238.95 Sale price
Keep your communication lines secure with our top-quality communication security wire. Made with Communication Security Wire 22AWG 4C Shielded with Drain, Plenum Rated, 1,000 Ft with drain, and plenum rated, this wire is designed to protect your sensitive data from interference and eavesdropping Ezlo.
With a length of 1,000 ft, you can easily install it in your office or home without worrying about running out of wire. Whether you're looking to set up a secure network or want to protect your sensitive communications, our communication security wire is the perfect solution for all your needs. Get yours today and enjoy peace of mind knowing that your communications are safe and secure.
Manufacturer Part # 22/4SHP
Conductors 4 – 22 AWG (7/30) bare copper 0.03 inch
Dielectric 7 mil wall of polyvinyl chloride colored per the chart to a nominal diameter of 0.044 inch
Cabling Cable four insulated conductors into pairs in a 1-1/2-inch left hand lay per the color code and wrap pair #1 with an overall aluminum/polyester tape (foil out) and a 24 AWG (7/32) tinned copper drain. Nominal diameter of 0.117 inch
Jacket 15 mil wall of gray colored polyvinyl chloride to a nominal diameter of 0.147 inch
Insulation Colors One (Shielded): Black / Red
Two (Unshielded): White/Green
Jacket White
Marking 22 AWG 2 PAIRS ONE SHLD (ETL)us TYPE CMR OR CL2R OR FPLR 3054355
Shop Communication Security Wire 22AWG 4C Shielded Ezlo
