Cat6e Cable, Direct Burial, Shielded, Gel-Filled, 1,000 Ft.
Regular price $336.95
Regular price $336.95 Sale price
Looking for a reliable and durable solution for your networking needs? Look no further than our Cat6e Cable, Direct Burial, Shielded, Gel-Filled, 1,000 Ft. This cable is designed to withstand harsh outdoor environments and direct burial applications, making it the perfect choice for outdoor installations. The shielded design ensures maximum protection against interference, while the gel-filled interior provides additional protection against moisture and other elements. With a length of 1,000 feet, this cable is perfect for larger installations and offers plenty of flexibility for routing and connecting your devices. Trust in our Cat6e Cable for a reliable and high-performance solution for your networking needs.
Manufacturer Part #: CAT6SH-DB
Sheath Printing: STRUCTURED CABLE PRODUCTS – – – P/N CAT6SH-DB – – – CAT6 SHIELDED DIRECT BURIAL ENHANCED 550 MHz 4 PR 23 AWG SOLID F/UTP GEL FILLED LLDPE VERIFIED TO ANSI/TIA-568-C.2 CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXX FEET MM/YY
Category: F/UTP- GEL CAT6-4P-PE
Test Standard: ISO/IEC11801, TIA-568-C.2 YD/T1019
Conductor: Material: SOLID-Bare Copper
Conductor Nom. O.D.: 0.565 mm, ±0.005 mm
Insulation: Material: HDPE
Insulation Diameter: 1.12 mm ± 0.03 mm
Screening Material: Mylar plus AL/Mylar
Sheath Thickness: 0.60 ±0.05 mm
Sheath External O.D.: 7.8 mm ± 0.4 mm
U.V Stability: U.V Resistant
Sheath Material: LLDPE (complies RoHS)
Sheath Color: Black
Surface Printing: Letter Height: 3.0 mm ±0.3mm, Color: White, Print Error / Space: =10.0 Mpa
Elongation: >=350 percent
Aging Period: 100°C x 24hrs x 10d
After Aging Elongation: >=300 percent
Cold Bend Test: -20°C 4 hours; No Cracking; 8x Cable O.D.
Electrical Characteristics (20°C):
Delay Skew: <=45 ns/100m
Velocity Of Propagation: 68 percent
Unbalanced-to-Ground Capacitance: Max 330 pf/100m
DC Resistance Max: 9.38 ohms/100m
DC Conductor Resistance Unbalance Max: 5.0 percent
