Communication Security Wire, 18AWG, 6C, Direct Burial, Shielded with Drain, 1,000 Ft.
Regular price $626.95
Regular price $626.95 Sale price
Introducing our top-of-the-line Communication Security Wire, 18AWG 6C, Direct Burial, Shielded with Drain, 1,000 Ft. – the ultimate solution for secure communication needs. This high-quality wire is constructed with 18AWG and 6C design, ensuring maximum durability and performance.
The Direct Burial feature allows for safe and reliable installation underground, while its shielded design offers superior protection against interference and signal loss. The wire is also equipped with a drain for added safety and peace of mind. With a length of 1,000 Ft., this Communication Security Wire is perfect for a wide range of applications, including security systems, intercoms, and more. Get your hands on this reliable and efficient wire today and enjoy uninterrupted communication!
Manufacturer Part # 18/6SH-DB
Marking STRUCTURED CABLE PRODUCTS ——— P/N 18/6SH-DB ——— 6 COND 18 AWG STRANDED SHIELDED PE JKT CMX OUTDOOR / DIRECT BURIAL —— CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXXFT
Standards: UL 444; NEC Article 760 & NEC Article 725; CE, EU, RoHS, EC
Conductor Material Stranded Bare Copper
Size 18AWG X 6C
Construction 16/0.254 ±0.004mm
Insulation Material PVC
Min. Thickness 0.24mm
Avg. Thickness 0.27mm
Diameter 1.70 ±0.05mm
Colors Black & Red & White & Green & Blue & Brown
Shield Core Wrap PE Tape
Drain Wire 7/0.20 ±0.004mm
Shield AL Foil
Filler Waterproof
Jacket Material LLDPE
Min. Thickness 0.54mm
Avg. Thickness 0.60mm
Diameter 7.20 ±0.10mm
Color Black
Conductor Resistance (18AWG) Max 22.8 ohm/km at 20°C
Dielectric Strength Min AC1.5KV
Rated Voltage Max 300 Volts at 75°C
AC Leakage Current Through Overall Jacket AC 1500V ≦ 10mA
Cold Bend Test -20°C at 4 hours – No Cracking
Insulation (PVC) Unaged Tensile Strength: 13.8Mpa
Elongation: 150 percent
Aged: Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h)
Jacket Unaged Tensile Strength: 10.8Mpa
Elongation: 300 percent
Aged: Tensile Strength: 9.2Mpa (100°C 168h)
Elongation: 150 percent (100°C 168h)
Communication Security Wire 18AWG 6C | Burial Shield 1000FT Shop Communication Security Wire 18AWG 6C Ezlo
