Introducing our Communication Security Wire, a reliable and high-quality wiring solution designed to keep your communication systems secure and running smoothly. This wire is constructed with 18AWG and features 2C, ensuring consistent and stable signal transmission. The unshielded design provides flexibility and ease of installation, while the 500 Ft. length ensures you have ample wiring to complete your project. Our Communication Security Wire is ideal for a variety of applications, including security systems, intercoms, and more. Invest in the best with our Communication Security Wire and enjoy reliable and secure communication for years to come.
Manufacturer Part #
18/2-GY-500
Marking
STRUCTURED CABLE PRODUCTS – – – P/N 18/2 – – – 2 COND 18 AWG STRANDED TYPE CMR/CL2R FT4 75C — (UL) OR C(UL) E198137 CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXXFT
Regulatory
UL 444, NEC Article 760, NEC Article 725
Application
Security Cable
Construction Characteristics
Conductor Material: Stranded Bare Copper Size: 18AWG X 2C Construction: 16/0.24mm ±0.004mm Insulation Material: PVC Min. Thickness: 0.27mm Avg. Thickness: 0.30mm Diameter: 1.70mm ±0.05mm Colors: Black and Red Jacket Material: PVC Min. Thickness: 0.50mm Avg. Thickness: 0.55mm Diameter: 4.40mm ±0.10mm Rip Cord: Nylon Color: Gray
Electrical & Physical Characteristics
Rating: 75°C 300V Conductor Resistance: Max 24.4ohm/km at 20°C Dielectric Strength: Min AC1.5KV AC Leakage Current Through Overall Jacket: AC 1500V Cold Bend Test: -20°C 4 hours; No Cracking Insulation Unaged:
Tensile Strength: 13.8Mpa
Elongation: 150 percent Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h) Jacket Unaged:
Elongation: 150 percent Jacket Aged:
