The Chief THINSTALL Fixed Wall Display Mount is the perfect solution for securely mounting your 37-63 inch display to the wall. With its sleek and low-profile design, the mount provides a seamless installation that keeps your display close to the wall for a clean and modern look. Its universal interface allows for easy installation and compatibility with all VESA patterns up to 400 x 400 mm. Constructed from high-quality materials, the mount is built to last and can support displays weighing up to 125 lbs. Installation is quick and easy with the included hardware and step-by-step instructions. Upgrade your viewing experience with the Chief THINSTALL Fixed Wall Display Mount.
Depth from Wall: | 0.39″ (10 mm) |
Hole Pattern: | 200 x 200 mm to 800 x 500 mm |
Weight Capacity: | 125 lbs (56.7 kg) |
Maximum Screen Thickness: | 5″ (127 mm) |
Color: | Black |
Phoenix (verified owner) –
The product is firmly packed.
Zane (verified owner) –
Very well worth the money.
Nolan (verified owner) –
Liam (verified owner) –
David (verified owner) –
Very fast delivery.
