The Chief THINSTALL Fixed Wall Display Mount is the ultimate solution for mounting your TV or display securely and conveniently. Designed for 26-47 inch displays, this mount is perfect for those who are looking for a sleek and minimalist look in their home or office. Its ultra-thin design, measuring only 0.39 inches deep, ensures that your display remains as close to the wall as possible, giving you a clean and professional-looking installation. This mount is also incredibly easy to install, with its simple and intuitive design allowing you to quickly and easily attach it to the wall. Made from high-quality materials, this mount is built to last and is capable of supporting displays weighing up to 100 lbs. So if you’re looking for a reliable, easy-to-use and stylish wall mount for your display, look no further than the Chief THINSTALL Fixed Wall Display Mount.
Depth from Wall | 0.39″ (10 mm) |
Hole Pattern | 100 x 100 mm to 600 x 400 mm |
Weight Capacity | 125 lbs (56.7kg) |
Maximum Screen Thickness | 5″ (127 mm) |
Color | Black |
Daniel (verified owner) –
Good quality.
Tyler (verified owner) –
Good service.
Very fast delivery.
Zohar (verified owner) –
Good quality.
Matthew (verified owner) –
Good quality.
