Aprilaire Surface-Mount Temperature Sensor
(5.00)5 Reviews
In Stock
$19.95
SKU: RP8053
Brands:
The Aprilaire Surface-Mount Temperature Sensor is a top-of-the-line product designed to make your home or office climate control system more efficient and responsive. This sensor is easy to install and provides accurate temperature readings that allow your climate control system to adjust accordingly, ensuring optimal comfort and energy savings.
The surface-mount design makes it easy to install in a variety of locations, and the high-quality construction ensures long-lasting durability. Whether you’re looking to improve your home’s energy efficiency or simply want to ensure a comfortable environment, the Aprilaire Surface-Mount Temperature Sensor is the perfect addition to your climate control system.
Manufacturer Part #: 8053
UPC: 686720805301
Voltage: 24 VAC ±10 percent
Resistance: 10k at 25 degrees C (77 degrees F)
Tolerance: ±3 percent at 25 degrees C (77 degrees F)
Maximum Wire Length: 300 feet
Dimensions: 2-1/2(H) x 3-1/2(W) x 7/8(D) inches
Warranty: 5-Year
Customers Reviews
(5)
  1. Zane (verified owner)
    Good service.
    1 product
  2. Paul (verified owner)
    Very fast delivery.
    1 product
  3. Anthony (verified owner)
    Very fast delivery.
    1 product
  4. Samuel (verified owner)
    Very fast delivery.
    1 product
  5. Kai (verified owner)
    Good quality.
    1 product
Back to Top
chatsimple
