The Aeotec WallMote Quad is a 2-in-1 wall switch and remote control for Z-Wave home automation. Powered by a rechargeable battery, you can mount WallMote Quad on a wall anywhere in your home to use it as a wall switch using the provided wall-mount. As it attaches to its wall-mount using magnets, you can also easily remove it to use WallMote Quad anywhere in your home as a remote control and easily re-attach it to the wall later. Minimalist in its design so that it matches the décor of any home, WallMote Quad lets you directly control 8 different Z-Wave scenes; simply tap WallMote Quad’s touch-glass surface to change or enable a scene. Beautifully designed, WallMote Quad is a subtle 3.02 inches wide and 0.37 inches deep. Powered by Aeotec’s Gen5 technology and built upon Z-Wave Plus, it offers around 3 months’ battery life before it needs to be recharged via the provided USB cable.
Hayden (verified owner) –
The product is firmly packed.
