Ezlo SoftHub Setup
Linux Installation
1. Get your Credentials
If you don’t have a MiOS account already, you can create a free account instantly through mios.com
2. Install Docker
Download Docker for your preferred OS at docker.com
2. Install Docker
Once you have docker installed and ready you can downloadall images and provision your hub with a single command:
docker run --net host -v /var/run/docker.sock:/var/run/docker.sock --restart=always --name orchestrator-vhubzz us-east4-docker.pkg.dev/softhub-354014/softhub/orchestrator:latest /root/orchestrator vhub -start -option provision -username=your-Ezlo-username -password=your-ezlo-password -zwave=/dev/ttyUSB1
- Change
and fields with the credentials you have on the MiOS platform. - To enable Z-Wave support (via USB Z-Wave Stick), use this parameter: -zwave=/dev/ttyUSB1
- If you do not have a USB stick, remove the parameter.
Windows Installation
2. Use Windows Installer
Download and run the Windows installer.
You will see a new controller in your MiOS app as well as on your EZLogic dashboard which you can connect to like any physical controller:
Additional configuration for Z-wave Usb sticks
To initialize your Z-Wave device, you will need to go to settings, Z-Wave settings:
Reset your Z-Wave network.
This only affects your new virtual controller, it will hvnot affect other Ezlo devices you have. Once these steps are completed you can include and control Z-wave devices normally as you would with any other Ezlo hub.
We are very excited to introduce SoftHub to you and are eagerly awaiting your feedback. Please test and let us know what works, what doesn’t work and what features you’d like to see added!
Need additional help?
From initial setup to expanding your system, Ezlo will help every step of the way.
