Shop Zitech ZigBee Secure Your Home with the Zitech ZigBee 3.0 Door Sensor
Enhance your home security and automation with the Zitech ZigBee Door Sensor, a versatile device designed to monitor the opening and closing of doors and windows. This ZigBee 3.0 Window Sensor integrates seamlessly into your smart home ecosystem, providing real-time notifications and peace of mind
Instant Notifications: Receive immediate alerts on your smartphone whenever a door or window is opened or closed, ensuring you're always informed about activity in your home.
Alarm Alerts: The sensor sends alarms to alert you of any unauthorized access, enhancing your home's security.
Alarm Recording: Check open/close records and battery levels through the app, ensuring you never miss important events or run out of battery unexpectedly.
Device Sharing: Easily share sensor access with family members through the app, allowing everyone to monitor the status of doors and windows.
Low Battery Reminder: Automatic notifications alert you when the battery is low, so you can replace it promptly and maintain continuous protection.
Specifications
Power Supply: Requires two LR03-1.5V AAA batteries (not included)
Battery Life: Capable of up to 100,000 trigger events, ensuring long-lasting performance.
Wireless Type: Utilizes ZigBee 3.0 protocol for reliable and efficient communication.
Material: Constructed from durable ABS material.
Dimensions: Main body measures 71mm x 25mm x 20mm; small body measures 36mm x 10mm x 17mm.
Usage and Installation
The Smart Contact Sensor is easy to install using the included adhesive tapes—no tools or drilling are required. Ensure both sensor components are aligned properly, with a gap of less than 10mm for optimal performance. Please note that this sensor is not waterproof and is intended for indoor use only
By integrating the Zitech ZigBee Door Sensor into your smart home, you can enhance security, automate routines, and monitor access points remotely. Its compatibility with platforms like Alexa, Tuya, and Google Assistant allows for seamless voice control and integration into existing smart home setups.
