Zigbee/Wifi Mmwave Human Presence Sensor Radar Movement Body Motion Detection with Illuminance Tuya Smart Life Home Assistant
Regular price $40.20
Regular price $0 $40.20 Sale price
ZigBee/WiFi MmWave Human Presence Sensor Radar Movement Body Motion Detection With illuminance Tuya Smart Life Home Assistant
Main Features:
1.Functional Smart Human Presence Sensor
2. Perceived Light Intensity for Smart&Scene Linkage
3.Comes With a Multi Angle Magnetic Bracket.
Sensors have magnetic attraction function, which can directly magnetically attract to iron. For example, iron table corners, iron frames, and steel beams.You can also use double-sided tape to directly stick it to the place where you need to install.
The sensor is magnetically attached to the bracket and then glued to the desired area using double-sided adhesive. For example, on the wall or ceiling. And the bracket allows for angle adjustment.
(Note: The back of the sensor has magnetism, and there is metal on the bracket. Therefore, achieving magnetic attraction function.)
4.Newly updated debug mode.
The debug mode is used to find the most suitable detection distance.This helps to eliminate sources of interference.
5.Newly updated Range Report Mode settings.
Setting it to "report at trigger" can reduce reporting logs. This will not cause network congestion for ZigBee2mqtt.Compared to other sensors present in the human body, it may be more friendly to the ZigBee network.
6. ZigBee Hub as Control Center
Tuya ZigBee gateway is required for this ZigBee human presence sensor,performing as the center bridge for all Tuya ZigBee smart devices with extremely stable signal and a really good necessity for whole-house intelligence.(note:Tuya ZigBee hub is highly recommended for its wider compatibility than other hubs)
If you need to use ZigBee2mqtt in home assistant. As this is a brand new device, if you want to add it directly to ZigBee2qmtt, please download the JS file from the following link.
https://github.com/wzwenzhi/Wenzhi-ZigBee2mqtt
Note: In version 1.3.9 ZigBee2mqtt. There is a bug in the interface between z2m and TI chip. After testing, the error pop-up does not affect data distribution, but it may cause errors in some of the distributed data content. Therefore, after the setting is completed, it is best to power off the sensor and then power it back on to check if there are any parameter setting failures. Suggest using the old version z2m and waiting for the new version to fix bugs.
Network: ZigBee / Wifi.
Radar: 5.8G
Input: USB Type-C DC 5V 1A.
Working temperature: -10ā„ƒ~+40ā„ƒ
Sensitivity: 10-100%(default 80%)
Detection Range: 1-10m(Default 6m)
Illuminance Sensor: 0-9999.9 LUX(relative value).
Entry Filter Time:0.05S-0.5S(Default 0.1S)
Departure Delay: 5S-120Min(Default 5S).
Beam Angle: 120*120°(5.8G) / 100*100°(24G)
Sensor Size: 48x48x20mm / 1.89*1.89*0.79in
Bracket Size: φ40mm*H36mm / φ1.57in*1.42in
Various Detection Functions
1. Fretting Detection: It can detect small movements such as tilting the head, waving, raising the hand, flicking the body, playing with the mobile phone, turning over the book, etc.
2. Presence Detection:It can detect the human body in the stationary state.
3.Motion Detection: It can detect walking, trotting, fast running, circling, jumping and other movements.
4. Distance measurement: The target distance measurement function can accurately filter targets outside the area.
New Feature Updates 1: Debug Mode
The debug mode is used to find the most suitable detection distance.This mode is turned off by default. When the debug mode is turned on, the indicator light will be turned on if someone is detected within the range, and the data reporting function will be turned on. If no one is detected within the range, the indicator light will be turned off.Timely distance can be used to determine the distance of interference sources.When the interface displays a countdown, if the radar does not detect the target, it wiil enter the countdown.
New Feature Updates 2: Range Report Mode
This can reduce frequent reporting information.
New Feature Updates 3: Magnetic Funtion
1. Sensors have magnetic attraction function, which can directly magnetically attract to iron. For example, iron table corners, iron frames, and steel beams.You can also use double-sided tape to stand anywhere you need to install it.
2.The sensor is magnetically attached to the bracket and then glued to the desired area using double-sided adhesive. For example, on the wall or ceiling. And the bracket allows for angle adjustment.
Illuminance detection
The detection range is 0-9999.9lux. A larger range of relative values. Adopt more accurate photosensitive sensors.
Adjustable Parameters
Various parameters such as detection distance can be set through app.
1.Detection shield:The closest detectable distance for the target.
2.Detection range:The farthest detectable distance for the target.
3.Trigger distance:The distance at which a sensor is triggered in an 'unoccupied' state.
4.Maintain sensitivity:The sensitivity for continuous detection of targets in an 'occupied' state.
5.Trigger sensitiveity: The sensitivity of triggering the sensor in an 'unoccupied' state.
6.Departure delay:After the target disappears, the delay in
reporting the 'unoccupied' state.
7.Entry filter time:The time it takes to confirm and report the
"occupied" state after a target is detected.
8.Block time:After transitioning from an "occupied" to an "unoccupied" state, the sensor does not detect targets during the lockout period.
9.Status indication:Indicator Light Switch.
10.Sensor:Sensor's Operational Status.
11.Range reprot mode:Target Distance Reporting Mode.
Product Size
Example installation method: ceiling mounted.
Presence Detection Range (5m)
Micromotion Detection Range (7m)
Motion Detection Range (10m)
Package list:
Sensor unit x 1
Mounting bracket x 1
Mounting adhesive x 1
USB power cable x 1
User Manual x 1
