Noted:It won't work with tuya zigbee hub.just work with home assitant zigbee2mqtt.
Discription:
• Zigbee Communication Method :The Zigbee Water Leak Detector uses Zigbee communication method, ensuring a stable and reliable connection.
• Smart Life App Alert :Receive alerts on your smartphone via the Smart Life app when the water leak detector detects any leaks or floods.
• Overflow Water Leakage Sensor :The overflow water leakage sensor ensures that you are alerted even before any damage occurs
• Kitchen/Bathroom Use :The Tuya Zigbee Water Leak Detector is perfect for use in kitchens and bathrooms, where water leakage is a common problem.
Note :Such product need to work with Tuya Zigbee Gateway or work with home assistant,zigbee2mqtt,ZHA
Tuya Zigbee Water Leak Detector Water Flood Sensor Smart Life App Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
Material: ABS
System support: l0S8.0/Android4.0 and above
App name: Smart Life/TUYA
Product Size:5*5*1.5CM
Package Included:
1 * water sensor
1*manual
Start Building Your Ezlo Home
Zigbee Water Sensor Flood Leak Detector App Remote Monitoring for Kitchen/Bathroom Support Home Assistant Zigbee2Mqtt
Have an Account?
Loading...
