Zigbee Humidity Temperature Tester Garden Automation Irrigation Detector Temperature and Humidity Meter for Plants
Regular price $36.96
Regular price $0 $36.96 Sale price
Zigbee Humidity Temperature Tester App Remote Monitoring Garden Automation Irrigation Detector Temperature and Humidity Meter for Garden
Features:
1.Remote Soil Monitoring: Efficiently track soil moisture using a garden automation irrigation detector without direct presence. Provides fast response and accurate measurements, giving you real-time data on current soil status.
2.Voice Control Compatibility: This soil moisture sensor is compatible with voice control, allowing easy integration with voice assistants like for Alexa or for Google Home to monitor soil moisture levels seamlessly.
3.Multi-Mode Calibration: Supports various calibration methods including temperature and humidity meter modes, ensuring precise data for both air and soil conditions.
4.Adjustable Sampling Time: Easily adjust sampling intervals between 0 to 1004 seconds for timely detection using the humidity temperature tester, enhancing control over environmental monitoring.
5.Intelligent Water Shortage Alert: Set parameters for the moisture meter to notify you when water levels are insufficient, ensuring timely action to maintain optimal soil conditions.
Specification:
Origin: Mainland China
Working voltage: DC 3.0V
Standby current: ≤ 20μA
Temperature resolution: 0.1℃
Humidity resolution: 1%
Temperature measurement accuracy: ±0.5°
Humidity measurement accuracy: ±5%
Working humidity: up to 99% RH
Wireless protocol: Zigbee 3.0
Working temperature: 10°C to 55°C
Battery type: AAA x2 (not included)
Zigbee gateway: required
Working APP: Tu-ya/Smart Life
Voice control: for Alexa/for Google Home
Product size: 150*30*18mm/5.91x1.18x0.71inch
Note: This product needs to be connected to the zigbee3.0 gateway to use!
Warm Tips:
This product has stable quality, but it cannot be guaranteed to be used correctly all the time. Please check and maintain the device regularly, and check the APP data records; pay attention to the battery usage and status. Avoid installing the device outdoors. The device has certain waterproof and dustproof functions, but it does not support long-term use in the rain.
Note:
Due to different monitor settings and lighting conditions, the actual color of the item may vary slightly from the pictures. Thanks for your understanding!
Please allow a 1-2 cm difference in measurements due to manual measuring.
1 x Soil Moisture Sensor
1 x Instructions
