4-in-1 ZigBee Tuya – Full suite with Temp & Humidity (Works with Tuya)
📡 Connectivity Note – Must Read Before Purchase: • If you choose the ZigBee Tuya version, you must use a ZigBee Tuya Gateway and the Smart Life / Tuya App. • If you choose the ZigBee Z2M version, it works with Zigbee2MQTT by zigbee 3.0 gateway(usb dongle)
• If you choose the normal version, it use a zigbee 3.0 hub to pair with app.
❌Not support ewelink app, Not support zigbee home automation(ZHA)
✅ All versions require a ZigBee gateway to connect to your app.Please ensure you have a compatible ZigBee gateway before purchasing.
🛠️ Optional Accessories:
Mounting Bracket Sold Separately – Ideal for angled or wall-mounted placement.
🔋 Battery Not Included – Please use non-rechargeable batteries.
❌ No USB Cable or Power Adapter Included – Use your own Type-C cable if needed.
🏠 One Sensor Per Room Recommended – For best accuracy, use one sensor per room.
Feature : 🔍 Precision Detection Technology 24GHz Radar Sensing(only for certain verison): Accurately detects human presence, movement, and even stationary states . Real-time alerts for presence or no-presnece help you respond quickly to unusual situations.
Dual-Sensor Fusion (Select Versions): Combines mmWave Radar + PIR for enhanced accuracy and fewer false alarms.
Adjustable Sensitivity: Customize motion & stationary detection ranges to fit your specific needs.(only for certain verison)
🌡️ Multi-Sensing Capabilities Light Sensor(only for certain version): Measures ambient brightness and automates smart lighting (e.g., lights on/off with motion).
Temperature & Humidity Monitoring (4-in-1 versions only): Keep track of your home’s environment for better comfort.
Battery or Type-C Power(only for certain version): Use batteries (up to 240 days lifespan) or Type-C cable for continuous operation.(type-c able not included)
📲 Smart Alerts & History Logs Receive instant app notifications when motion is detected.
Review detection history to monitor activity over time.
✅ Recommended Use Cases 👵 Elderly Care: Monitor daily activity and receive alerts if no movement is detected.
🏠 Home Security: Detect intruders or unauthorized movement.
💡 Smart Lighting: Auto-turn on/off lights based on presence and ambient light.
🌿 Climate Control: Monitor and automate temperature & humidity (4-in-1 versions).
📦 What’s Included? 1 x Smart Sensor(not battery, not cable)
