Zigbee Dimmer Switches Tuya APP Control Smart LED Dimmable Series Glass Google Alexa Smart Dimmer Touch Switches Black
Regular price $54.70
Regular price $0 $54.70 Sale price
BSEED Zigbee Dimmer Switches Tuya APP Control Smart Dimmable Series White Glass Support Google Smart Life LED Dimmer Switches
Features:
1. Popular Color are available:White,Black,Golden
2.Our Wifi home socket and switch are Fireproof and Waterproof. Protection Against Electric Shock for Your Family.
3. Made of Premium Quality Tempered Glass and PC Plastic Material,offers excellent Scratch Resistance.
4. Different quality testing during production, to ensure each switch work well before it is delivered to customers.
5. Elegant look, Suited greatly with many modern decor styles. It can be applied to drawing room, bedroom, corridor, kitchen, bathroom, Office and so on.
wifi and zigbee:
WiFi's wireless stability is relatively weak, and high power consumption is also one of its weaknesses. In addition, WiFi's networking capability is relatively low. There is also a certain impact on the user experience.
The biggest feature of ZigBee is high security, low power consumption, and networking, suitable for automatic control and remote control, and can be embedded in various devices.
App Installation:
Download The Tuya Or Smart Life App To Your Smartphone Or Tablet. The App Can Be Downloaded From Apple App Store or Google Play, Then Connect Your App With Amazon Alexa Or Goggle Home Which Enable You To Voice Control Your Lights And Appliances.
Questions:My device on the app stays “Off line”?
Answer: The new added device needs 1min to connect to Zigbee HUB. If it stays off line for a long time, please judge the problem by the Zigbee LED status:
Zigbee LED quickly blinks one time every second, device failed to connect to your Zigbee:
(1)Maybe you have entered wrong WiFi password.
(2)Device is too far away from your WiFi. Please take it closer.
If still failed, try to open a mobile hot spot and add again.
Zigbee LED quickly blinks twice every second: Device has connected to Zigbee but failed to connect to server. Please check your network connectivity.
Product Introduction:
Max. Strom: 10A
Load: 1000W/Gang
Wireless consumption: ≤0.5W
Max. Spannung: 90-250V(AC)
Relative Humidity:10% ~ 93%
Working Temperature: -30 ℃~+70℃
Certification:CE, BS, RoHS, GCC, FC
WiFi Frequency: IEEE802 15.4
WIFI Standard: Zigbee 2.4GHz b/g/n
APP: Tuya/Smart Life
Voice Control: Google Home, Amazon Alexa
Wire: Need Neutral Wire
Back Light: ON-light Blue OFF-Weak Blue
Moduel shape:Round
Wall Box Type:Round & Square
Note:
You have to cut off the power and during the installation.
FAQ:
Q: Does your ZigBee dimmer touch sensor light switch need a neutral wire to install?
A:Yes
, it needs a neutral wire to install.
Q: Does your touch dimmer switch can work with the ZigBee gateway hub?
A:Yes, Our item works the tuya gateway hub.
Q: Does your ZigBee dimmer light switch can work with Smart Life Tuya or Google Alexa?
A:Yes, it can work with them.
Q: Do you offer a 2-way ZigBee touch light switch?
A:No, the ZigBee dimmer switch has 1-way
Q: Does your ZigBee touch dimmer switch have a backlight?
A:The blue backlight will be on when the wiring is successful. Allowing you to notice Our touch switch clearly in the dark.
Q: Does our switches can install vertically or Horizontally for 157mm/228mm glass panels?
A:Yes, we can install it in different ways, but you will see the small holes. (The small holes used to open the glass cover)
