Zigbee Alexa Switch Accessorie Parts Smart Wall Switch Touch Sensor Function Key Neutral Required Support Tuya Google Home
Regular price $35.12
Regular price $0 $35.12 Sale price
BSEED Zigbee Alexa Switch Accessorie Parts Smart Wall Switch Touch Sensor Function Key Neutral Required Support Tuya Google Home
Product Introduction:
Max. Strom: 10A
Load: 1000W/Gang
Wireless consumption: ≤0.2W
Max. Spannung: 90-250V(AC)
Relative Humidity:10% ~ 93%
Working Temperature: -30 ℃~+70℃
Certification:CE, BS, RoHS, GCC, FC
WiFi Frequency: IEEE802 15.4
WIFI Standard: Zigbee 2.4GHz b/g/n
APP: Tuya/Smart Life
Voice Control: Google Home, Amazon Alexa
Wire: Need Neutral Wire
Back Light: ON-light Blue OFF-Weak Blue
Moduel shape:Round
Wall Box Type:Round & Square
Multi-Control Function :1/2/3/4Way ,Control Light From Different Positions
Note:
You have to connect to wifi through zigbbee gateway hub.
You have to cut off the power and during the installation.
App Installation:
Download The Tuya Or Smart Life App To Your Smartphone Or Tablet. The App Can Be Downloaded From Apple App Store or Google Play, Then Connect Your App With Amazon Alexa Or Goggle Home Which Enable You To Voice Control Your Lights And Appliances.
Questions:My device on the app stays “Off line”?
Answer: The new added device needs 1min to connect to Zigbee HUB. If it stays off line for a long time, please judge the problem by the Zigbee LED status:
Zigbee LED quickly blinks one time every second, device failed to connect to your Zigbee:
(1)Maybe you have entered wrong WiFi password.
(2)Device is too far away from your WiFi. Please take it closer.
If still failed, try to open a mobile hot spot and add again.
Zigbee LED quickly blinks twice every second: Device has connected to Zigbee but failed to connect to server. Please check your network connectivity.
FAQ:
Q: Does your Zigbee touch sensor light switch need a neutral wire to install?
A:YES
, it needs a neutral wire to install.
Q: Does your zigbee switch needs to work with some other device?
A:Yes,Our Zigbee Switch needs to work with gateway hub to connect to wifi ,pls make sure you have it before buying. you can also order the gateway hub from our store .
Q: Does your light switch can work with Smart Life Tuya Google Alexa or Yandex Alice?
A:Yes, it can work with them.
Q: Can i control the zigbee switch from 2-3 different places for same light ?
A:Yes, our zigbee switch can achieve 2-3way, it functions stably.But you must at least buy 2-3 pieces ZigBee switches. ( APP use multi-control association function)
Q: Does your ZigBee touch light switch have a backlight?
A:The blue backlight will be on when the wiring is successful. Allowing you to notice Our touch switch clearly in the dark, it can't be cancelled .
Q: Does our switches can install by vertically or Horizontally for 157mm/228mm glass panels?
A:Yes, we can install it in different ways, but you will see the small holes. (The small holes used to open the glass cover)
