Zigbee 3.0/Wifi Human Presence Sensor 5V Mmwave Radar with Siren Alarm Motion Lux Detection Tuya/Smart Life Home Automation DIY
Regular price $60.08
Regular price $0 $60.08 Sale price
ZigBee 3.0/Wifi Human Presence Sensor 5V MMwave Radar With Siren Alarm Motion Lux Detection Tuya/Smart Life Home Automation
Main Features:
1.Functional ZigBee Smart Human Presence Sensor
2. Perceived Light Intensity for Smart&Scene Linkage
3.Safeguard your family safely. Built in 120db alarm.
There are three modes available on the APP homepage: Armed/Disarmed/Alarming. You can also set the alarm duration and volume in the APP. In Armed mode, the sensor detects the presence of a person and emits an alarm sound. If you don't want to hear the alarm sound, you can switch to Disarmed mode
4. Advanced New Design with Multiple Settings
In addition to setting alarm related parameters in the APP. It can also support setting the following parameters: Presence Keep Time/Indicator Status/Radar Parameters(Sensitivity and distance)/Motion False Detection.
5. 5.8G/24G Radar Optional
What is the difference between 24G and 5.8G? The 24G version has lower false positive rates and more accurate features. In daily use, 5.8G is sufficient. However, in more complex usage environments, it is recommended to use the 24G version.
6. ZigBee Hub as Control Center
Tuya ZigBee gateway is required for this ZigBee human presence sensor,performing as the center bridge for all Tuya ZigBee smart devices with extremely stable signal and a really good necessity for whole-house intelligence.(note:Tuya ZigBee hub is highly recommended for its wider compatibility than other hubs)
Network: ZigBee / Wifi.
Radar: 5.8G With breath detection / 24G
Input: USB 5V
Siren Alarm Volume: Max 120db
Working temperature: -10ā„ƒ~+55ā„ƒ
Indicator Light:Red + Blue Indicator Light
Detection Angle:110°
Detection Distance: 6m/19.69ft
Illumination Value: 0~2000lux
Product Size: Φ85mmƗ27mm/Φ3.45inchƗ1.06inch
Package list:
Human presence sensor*1
User manual*1
2m USB Cable*1
Mounting screw packing
Reset needle*1
Armed/Disarmed/Alarming Mode:
Armed: When the sensor detects the presence of a person, it will sound an alarm. The alarm duration and volume level can be set in the Setting page.
Disarmed: When the sensor detects the presence of a person, the sensor will not emit an alarm sound.
Alarming: Regardless of whether the sensor detects the presence of a person. Manually activate the alarm sound.
Various Detection Functions
1. Fretting Detection: It can detect small movements such as tilting the head, waving, raising the hand, flicking the body, playing with the mobile phone, turning over the book, etc.
2. Presence Detection:It can detect the human body in the stationary state.
3.Motion Detection: It can detect walking, trotting, fast running, circling, jumping and other movements.
4.Breathing Detection: Sensors can detect the breathing of people within a certain range to determine the presence of people in the detection area. For example, while sleeping or reading.
Illuminance detection
Detectable illuminance value
Adjustable Parameters
Various parameters such as detection distance can be set through app.
Product Description
ā‘ Illuminance sensor
ā‘”Radar sensing surface
ā‘¢Indicator light
ā‘£Micro USB port
⑤Support mounting hole
ā‘„Loudspeaker
⑦SET button
Celling Mount Installation
1.Secure the mounting bracket to the ceiling using screws.
2.Buckle the device into the mounting chassis, rotate to secure it, press the mounting chassis into the support, and tighten it, as shown in the diagram on the right.
3. Adjust the radar sensing surface Angle and align it with the area to be detected.
Wall Mount Installation
Wall mount installation, can effectively reduce the product on the movement of small animals false detection.
1.Attach the mounting bracket to the wall using screws.
2.Buckle the device into the mounting chassis, rotate to secure it, press the mounting chassis into the support, and tighten it, as shown in the diagram on the below.
3.Adjust the radar sensing surface Angle and align it with the area to be detected.
Special Attention!
1.Do not expose radar sensing to jamming devices such as quasi-wireless routers.
2.Do not aim the radar at moving curtains.
3.2.You can set radar parameters on the APP according to the field environment, adjust the sensor detection distance.
