Zigbee 3.0 Smart PIR Motion Detector Optional Light Intensity Vibration Sensor Security Alarm System Support Home Assistant Z2M
Regular price $13.40
Regular price $0 $13.40 Sale price
*Only support for zigbee 2mqtt.Compatible zigbee hub is required ,.they cannot work alone without related gateway.
❌Not support for tuya zigbee gateway nor ewelink zigbee gateway;
❌Not support for tuya smart nor smart Life App
❌Not support for ZHA(zigbee home automation)
What is the difference between these versions?
Type 1.Motion Sensor: it is only zigbee pir motion sensor;
Type 2.Motion(Bracket):Zigbee pir motion sensor + bracket;
Type 3. 2 IN 1 : zigbee pir motion sensor with illuminance detection;
Type 4. 2 IN 1(Bracket) : zigbee pir motion sensor with illuminance detection + bracket;
Type 5. 3 IN 1 : zigbee pir motion sensor with illuminance detection and vibration detection;
Type 6. 3 IN 1(Bracket) : zigbee pir motion sensor with illuminance detection and vibration detection + bracket;
Product name:ZigBee human pir motion sensor
Networking form: ZigBee3.0
Detection:105°,distance < 5M
Power input:Cr2450 button battery(Included)
Operating Temperature: -10C~55℃
Operating Humidity: 0%~99%RH
Product size:33mm*26mm
Features:
【Zigbee Bridge/Zigbee hub/Zigbee gateway Required】:The pir sensor must work with zigbee2mqtt via related zigbee gateway;
【Do not compatible with tuya smart nor smart life nor ewelink gateway 】: these app and gateway is not compatible;
【Advanced Motion Sensor】 PIR detects human body or animals that are moving, 105° detection angle, 5m detection distance, can achieve real-time monitoring day or night. Sensitive sensing of human/pet movement.
【Real Time Detection】 When there is movement detected, the Z2M sensor status will be'true', it means some one was detected by motion sensor ,be aware of what's happening at home even when you're away.
【History Records Tracking】 You can track the history of sensor activities.
【Strong Performance & Ultra-long Standby Time】 Long transmission distance, high sensitivity, and strong network signal. Ultra-long standby time. Powered by 1pcs CR2450 batteries(Included).
【Intelligent linkage and enjoy the new life】: It can be connected to zigbee2mqtt and link with other zigbee smart products in the home .
