ZigBee 3.0 Air Conditioning Compressor Thermostat Fan Coil Unit Digital Temp Conditioner 220V Tuya Smart Life Alexa Google Home
Regular price $111.42
Regular price $111.42 Sale price
Shop ZigBee 3.0 Air Conditioning Compressor Thermostat Fan With Effortless Temperature Control
Introducing the ZigBee 3.0 Air Conditioning Compressor Thermostat Fan Coil Unit Digital Temperature Conditioner 220V, a cutting-edge solution for efficient and smart climate control in your home or office. This advanced Thermostat Fan Coil system is designed to provide precise temperature management, ensuring optimal comfort while maximizing energy efficiency.
  • Modern Touch Screen Design: The thermostat boasts a sleek, modern design with an acrylic lens to prevent finger scratches. Its touch-button interface ensures simple operation, and the large backlit screen is easy to read, even in the dark.
  • Programmable Schedules: With four programmable periods, you can customize temperature settings to align with your daily routine, enhancing comfort and promoting energy savings.
  • Smart Home Integration: Seamlessly integrates with Tuya Smart Life, Alexa, and Google Home, allowing for remote control and voice commands. Please note, a Tuya ZigBee Wireless Gateway Hub is required for operation.
  • Precise Temperature Control: Maintains your desired temperature within 0.5°C, ensuring consistent comfort throughout your space.
  • Easy Installation: Compatible with 86mm hidden boxes and European 60mm round boxes, facilitating straightforward installation.
  • Enhanced Comfort: The Fan Coil Thermostat allows for precise temperature adjustments, ensuring a comfortable environment tailored to your preferences.
  • Energy Efficiency: By utilizing programmable schedules and accurate temperature control, this thermostat helps reduce energy consumption, leading to potential cost savings.
  • Convenient Control: Integration with popular smart home platforms enables remote operation and voice control, offering unparalleled convenience.
Ideal for controlling fans and valves in air conditioning systems, this thermostat compares room temperature with your set temperature to achieve the desired climate efficiently. It's suitable for various settings, including homes, offices, and commercial spaces, providing reliable performance and user-friendly operation.
Technical Specifications
  • Model Number: BAC-002
  • Power Supply: 95240VAC, 5060Hz
  • Temperature Range: 5~35℃
  • Sensor: NTC built-in sensor
  • Certification: CE, FCC
Upgrade your climate control system with the ZigBee 3.0 Air Conditioning Compressor Thermostat Fan Coil Unit Digital Temperature Conditioner 220V, and experience the perfect blend of comfort, efficiency, and smart technology.
