X10 PRO Wired-In Noise Filter, 20A, 3-Wire
Regular price $37.95
Regular price $37.95 Sale price
Shop X10 PRO Wired-In Noise Filter
The X10 PRO Wired-In Noise Filter, 20A, 3-Wire is a critical component for maintaining a clean and stable electrical environment in your home or workplace. Engineered to eliminate electrical interference and noise from your power lines, this Wired-In Noise Filter ensures that all your connected devices, from home appliances to sensitive electronics, receive a consistent and interference-free power supply. With its robust 20A capacity and 3-wire configuration, this Smart Noise Filter is versatile and capable of supporting a wide range of devices.
Installation is straightforward, making it an ideal solution for both professionals and DIY enthusiasts. The Wired Noise Filter integrates seamlessly into your existing electrical system, providing long-lasting protection against the disruptions caused by noise and interference. Built to withstand the rigors of daily use, this filter is constructed with durability in mind, ensuring that your devices continue to perform at their best over time.
Whether you are looking to protect high-end electronics, improve the performance of your home automation systems, or simply ensure that your appliances operate smoothly, the X10 PRO Wired-In Noise Filter delivers the reliable performance you need.
Features:
  • 20A Capacity: Supports a wide range of devices, from small electronics to large appliances.
  • 3-Wire Configuration: Compatible with various electrical systems.
  • Effective Noise Reduction: Eliminates power line noise and interference to ensure consistent device performance.
  • Durable Construction: Built to last, offering long-term protection for your electrical system.
Usage:
  • Install the Wired-In Noise Filter directly into your electrical system to provide clean power to all connected devices.
  • Ideal for use with home appliances, home automation systems, and sensitive electronics.
  • Suitable for both residential and commercial applications.
Benefits:
  • Enhances the performance and longevity of connected devices by eliminating electrical noise and interference.
  • Provides a stable and reliable power supply, reducing the risk of malfunctions and damage.
  • Easy to install and integrate into existing electrical systems.
  • Offers peace of mind by ensuring that your electrical environment is optimized for performance.
Product Specs:
Installation: 3-Wire
Power Rating: 120 VAC at 60Hz, 20 Amps
Dimensions: 4.75(L) x 3(W) x 1.5(D) inches
