Shop X10 PRO Soft Start Dimmer Wall Switch With Smart Dimming Made Easy
The X10 PRO Soft Start Dimmer Wall Switch is a versatile solution for automating and dimming your home's lighting. Designed to replace standard single-pole switches, this device allows for both local and remote control of your incandescent light fixtures.
Soft Start Technology: Gradually increases brightness over two seconds when turned on, reducing eye strain and extending bulb life.
Remote Control Capability: Compatible with X10 controllers, enabling remote on/off and dimming functions.
Memory Function: Remembers the last dim setting, resuming to the same brightness upon being turned on again.
Power Cutoff Switch: Includes a manual cutoff for safe bulb replacement.
By integrating the X10 Wall Dimmer Switch into your home automation system, you can effortlessly control lighting in areas like the front porch, patio, hallways, and stairways. The X10 Soft Start Dimmer not only enhances ambiance with smooth lighting transitions but also contributes to energy efficiency by allowing precise brightness adjustments.
Specifications
Load Compatibility: Supports incandescent bulbs ranging from 40W to 500W.
Power Requirements: Operates on 120 VAC, 60 Hz.
Color: White.
Upgrade your lighting control with the X10 PRO Dimmer Switch, combining convenience, efficiency, and modern technology for a seamless home experience.
