X10 Pro Slave Switch
Regular price $19.95
Regular price $19.95 Sale price
Shop X10 Pro Slave Switch for 3-Way and 4-Way Lighting Control Smart & Efficient
The X10 Pro Slave Switch is an essential component for expanding your home's lighting control capabilities, enabling seamless operation of lights from multiple locations. Designed to work in conjunction with X10 wall switches, this master-slave switch system offers enhanced convenience and flexibility.
  • Compatibility: The X10 Pro Slave Switch is engineered to function alongside master switches such as the XPD3, XPDI3, and XPS3 wall switches, facilitating multi-way control setups.
  • Non-Load Bearing Design: This x10 switch transmits signals over dedicated traveler wires to the master switch, ensuring auxiliary control without directly bearing the electrical load.
  • Versatility: Ideal for creating 3-way, 4-way, or even more complex lighting configurations, allowing control of a single light source from multiple locations within your home.
To set up the X10 Pro Slave Switch, install it in the desired location and connect it to the corresponding master switch using traveler wires. This configuration enables synchronized control of your lighting system, providing the convenience of operating lights from various points.
  • Enhanced Convenience: Operate your lighting fixtures from multiple locations, making it easier to control lighting without the need to return to a single switch point.
  • Flexible Installation: The master-slave switch setup allows for easy expansion of your existing lighting control system without extensive rewiring.
  • Seamless Integration: Designed to work flawlessly with X10 wall switches, ensuring a cohesive and reliable home automation experience.
