X10 PRO 4-Button Keypad Plus Transmitter Base Kit
Regular price $50.95
Regular price $50.95 Sale price
Shop X10 PRO 4-Button Keypad Plus Transmitter With Streamlined Lighting & Appliance Control
The X10 PRO 4-Button Keypad Plus Transmitter Base Kit is an advanced in-wall controller designed to streamline your home automation experience. This versatile device allows you to manage up to four X10 receiver modules effortlessly, providing centralized control over various appliances and lighting systems.
  • Seamless Integration: The 4-button Keypad with Transmitter Base mounts into a standard single-gang wall box, connecting directly to your home's Hot and Neutral wires. This setup ensures a clean and unobtrusive installation, enhancing the aesthetic appeal of your living space.
  • User-Friendly Operation: Each button on the X10 PRO 4-Button Keypad corresponds to a specific X10 receiver. Press one side of a rocker switch to turn the connected device on, and the other side to turn it off, offering intuitive control at your fingertips.
  • Flexible Addressing: By setting the transmitter base to a desired House Code and Unit Code, the keypad's buttons can control receivers in sequential order. For instance, if configured to House Code B and Unit Code 4, the buttons will manage devices set to Unit Codes 4 through 7 on the same House Code.
The 4-button Keypad is ideal for homeowners seeking a centralized solution to control multiple X10 devices. Whether you're looking to manage lighting, appliances, or other electronic devices, this keypad offers a convenient and efficient method to enhance your home's automation system.
Specifications
  • Power Supply: 120VAC at 60Hz
  • Power Consumption: 2 Watts
  • Color: White
