Shop X10 Dimmer Wall Switch 500W Enhance Your Home Ambiance
The X10 Dimmer Wall Switch 500W is a versatile solution for enhancing your home's lighting control. Designed to replace standard wall switches, this device offers both local and remote X10 Dimmer control over your lighting fixtures.
Compatibility: Supports dimmable incandescent bulbs up to 500 watts, providing flexible lighting options.
Remote Control: Responds to X10 commands, including ON/OFF, BRIGHTEN/DIM, and ALL LIGHTS ON, allowing seamless integration into your existing X10 Dimmer home automation system.
Smooth Dimming: Adjusts lighting levels gradually over approximately 3 seconds, creating a comfortable ambiance.
Local Operation: Features a pushbutton for manual ON/OFF control and dimming functions, ensuring ease of use.
Power Cutoff Switch: Includes a safety switch for convenient bulb replacement without electrical hazards.
Ideal for living rooms, bedrooms, or any area where adjustable lighting is desired, the X10 Dimmer Switch 500W allows you to set the perfect mood with ease. Whether you're hosting a gathering or winding down for the evening, tailor your lighting to suit the occasion.
Enhanced Ambiance: Fine-tune your lighting to create the desired atmosphere in any room.
Energy Efficiency: Dimming lights can reduce energy consumption, leading to potential cost savings.
Convenience: Control your lighting remotely through X10 Dimmer controllers, adding a layer of modern convenience to your home.
Safety: The built-in power cutoff switch ensures safe and straightforward bulb changes.
Installation
Replacing your existing wall switch with the X10 500W Wall Dimmer is straightforward. Ensure the power is turned off at the circuit breaker, connect the appropriate wires as per the included instructions, and secure the switch in place. For multi-way circuits, additional companion switches may be required.
