The Winland EnviroAlert 4 Zones Digital Environmental Monitoring Alarm is a top-of-the-line device designed to help you monitor your environment and keep it within safe and optimal conditions. This alarm features four zones, which means you can monitor four different areas at the same time. It is equipped with advanced sensors that can detect changes in temperature, humidity, water, and other environmental factors that could potentially cause damage to your property or put your health at risk.
The EnviroAlert is very easy to install and use. It runs on 12VDC power and can be connected to your existing network for remote monitoring. The device also comes with a built-in alarm that will sound and flash when any of the monitored parameters go beyond the preset limits. This helps you take immediate action to prevent any damage or health hazards.
Whether you want to monitor your home, office, or any other environment, the Winland EnviroAlert 4 Zones Digital Environmental Monitoring Alarm is the perfect solution. With its advanced sensors, easy installation, and reliable performance, you can rest assured that your environment is always safe and healthy. The specification of Winland EnviroAlert 4 Zones Digital is below.
