The VMP Multi-Just Flat Panel Wall Display Mount is the perfect solution for mounting your 27-42 inch flat panel display securely and stylishly. This mount features a tilt function, allowing you to adjust the angle of your display for optimal viewing comfort. The Multi-Just design provides easy installation and adjustment of the mount, making it perfect for home or office use. The sturdy construction of this mount ensures that your flat panel display will remain safe and secure on the wall. The VMP Multi-Just Flat Panel Wall Display Mount is the perfect choice for anyone seeking a reliable and versatile mounting solution for their flat panel display.
Dimensions: | 19(W) x 15.75(H) x 2.3(D) inches |
Weight: | 5.55 pounds |
Load capacity: | 100 pounds |
Vertical height adjustment: | 1 inch |
List adjustment: | ±3 degrees |
Distance from wall to back of the flat panel: | 2.3 inches |
Maximum flat panel hole pattern: | 415 x 345 mm |
Customers Reviews
There are no reviews yet.
