Vision Water Leak Sensor
Regular price $11.97
Regular price $11.97 Sale price
This sensor is a Z-WaveTM enabled device (interoperable, two-way RF mesh networking technology) and is fully compatible with any Z-WaveTM enabled network and it’s security framework. Every main powered Z-Wave enabled devices act as a signal repeater and multiple devices result in more possible
transmission routes which helps eliminate “RF dead-sports” Z-WaveTM enabled devices displaying the Z-WaveTM logo can also be used with it regardless of the
manufacturer, and ours can also be used in other manufacturer’s Z-WaveTM enabled networks. This sensor sends Z-WaveTM signal while detecting water. The sensor can be put under the refrigerator, and it will trigger while detecting the leaking water. You can also install the sensor at anywhere it leaks; with this sensor you can avoid loss before it flood. When the device is secure included into Z-Wave network, above communication will be encrypted.
