Shop Tuya ZigBee 3.0 Smart Life Light Switch With 2-Way Control with Neutral
Upgrade your home lighting system with the Tuya Zigbee 3.0 Smart Life Light Switch. This innovative device combines modern technology with user-friendly features to provide seamless control over your lighting fixtures.
Zigbee 3.0 Protocol: Ensures robust and reliable communication between the switch and other smart devices, enhancing the stability of your smart home network.
Wireless Push Button Design: The sleek, wireless push button switch offers a modern aesthetic while providing tactile feedback for effortless operation.
Smart Life Integration: Compatible with the Smart Life light switch app, allowing for remote control, scheduling, and automation of your lighting from anywhere using your smartphone.
Two-Way Control: Supports two-way smart light switch functionality, enabling control of a single light from multiple locations, ideal for staircases and large rooms.
Voice Control: Works seamlessly with Amazon Alexa and Google Assistant, allowing for hands-free voice commands to control your lights.
No Neutral Wire Required: Designed to work without a neutral wire, simplifying installation in older homes where neutral wiring may not be present.
The Smart Life light switch is perfect for those looking to enhance their home's lighting control without extensive rewiring. Its wireless push button switch design allows for flexible placement, and integration with the Smart Life app provides comprehensive control over your lighting environment. The two-way smart light switch feature is particularly beneficial for controlling lights from multiple locations, adding convenience and efficiency to your daily routines.
ZigBee 3.0 Smart Wall Push Button Switch
1/2/3/4 Gang
Work with ZigBee Hub
Use with a ZigBee hub to realize the smart control
Sleep Mode
Turn off the room lights
Theater Mode
Turn off the living room light and turn on wall lights
Romantic Mode
Turn off the ceiling light and turn on downlight
