Tuya Zigbee WIFI Water Sensor 3.5Mm Jack 2M Sensor Cable Built-In Rechargeable Battery 80Db Alarm Sound App Real Time Monitoring
Regular price $42.90
Regular price $0 $42.90 Sale price
Tuya Zigbee WIFI Water Sensor 3.5mm Jack 2m Sensor Cable Built-in Rechargeable Battery 80dB Alarm Sound App Real Time Monitoring
Please note the zigbee version need to work with the tuya zigbee gateway. The package don't include the gateway.and also don't include the USB charging cable.
Technical parameter:
Power supply: 5V/1A
Rechargeable battery: 3.7V 450mAH
Recharge current : <125mA
Working current: <80mA
standby current: 25uA
Buzzer level: >80dB
Battery standby life : Above one year
water cable length: 2 meter
water cable jack width: 3.5mm width
Support WIFI: 2.4G
About this item:
  • ①【Reliable performance】:If the water sensor detects water leakage or a preset over limit, the water detector will emit a 80dB alarm sound, and the alarm will sound within 60 seconds and the alarm message will be sent within 2-10 seconds Send to smartphone (depending on network speed). To prevent possible water damage.
  • ②【Sound and light alarm】:Even if there is no WIFI, the scene can still emit a 80 dB loud alarm and a red flashing on-site alarm, even if there is a leakage in the basement, a sufficient sound can be heard
  • ③【Widely applicable】:Perfectly suitable for houses, warehouses, basements, continuous monitoring of sinks, dishwashers, household appliances, refrigerators, washing machines, sewage pumps, water heaters, hot tubs, water pipes and filtering devices. Swimming pool, bathtub, fish tank and sensors warn of water level.
  • ④【Battery Powered】:Built-in rechargeable battery (included), can be used for one year, and you can check its power on the application. 6.6 feet / 200 cm long water detection sensor cable for flexible placement
  • ⑤【Installation and use】:No need of gateway and complicated wiring, only a few simple steps to connect to home WiFi (only applicable to 2.4G WiFi). Whether you are in the office or on the go, you can use the TUYA / Smart Life app to check the status at any time. You can also share it with others, and more people can receive alerts and track the activity of wireless sensors.
