Note: zigbee sensor needs to be used with zigbee gateway
Wifi sensor does not need to be used with zigbee gateway
1. APP remote real-time monitoring-- You can monitor the temperature and humidity of your home in real time from anywhere.
You can also view historical temperature and humidity changes
2.Intelligent Linkage--You can set up the smart linkage function and associate it with other Tuya devices in your home, such as smart IR remote control.For example, the air conditioner will be on and turn to specified temperature automatically when the room temperature surpass 28ā. And the humidifier will spray when the humidity is lower than 20% RH.
3.Low battery alarm--The battery level can be monitored.
4.Temperature Unit Selection in APP-- You can choose ā or ā as the temperature unit through app.ļ¼Note:Zigbee Version does not contain this featureļ¼
5. Third-party Voice Control-- Works with amazon alexa, google assistant.
6.Share devices-- You can share your added devices with your family members, so they can also monitor the ambient environment.
